Black Inc Factor Israel-Premier Tech Pro Bike Stephen Williams Tech Tech features Tour Down Under #wordpress #wordpress-post-id-164903 #post-format-gallery
Pro bike: Defending TDU champion Stevie Williams’ Factor Ostro VAM
The Welsh climber had a breakout 2024 season aboard Factor's flagship all-rounder and is hoping to keep the momentum going.
Between 2024 and 2025 you’d be hard-pressed to find any changes with the equipment used over at Israel-Premier Tech. Since 2020 the team has been rolling aboard Factor bikes, Black Inc. wheels and Shimano groupsets. That trend looks set to continue for 2025 with the teams set up mirroring that of 2024.
At both Australian National Championships and the Tour Down Under last year, Factor and the IPT team caused a stir by displaying the new Ostro VAM a few weeks before its official launch. In that year’s edition of the TDU, Stephen "Stevie" Williams claimed a stage win and the overall GC. All of this exposure meant that by the time the bike officially launched, the new Ostro VAM had become the worst-kept secret in cycling.
Since then the Ostro VAM has been the team's go-to bike for most scenarios, with the exception of Paris-Roubaix where the team used the Ostro Gravel, and the O2 VAM on particularly mountainous terrain. Williams also rode the new Ostro to the win at Fleche Wallonne.
Williams is back in Adelaide for the 2025 Tour Down Under, looking to defend his title with arguably one of the strongest teams in the race. Backing him up there are the likes of George Bennett and Michael Woods bringing some firepower to the ProTeam for Willunga Hill.
Blending low weight and aero-optimised design, the Ostro VAM is part of the latest breed of do-it-all race bikes that represent a versatile one-bike strategy for many of the team's riders.
Israel Premier Tech Factor Ostro VAM
The Ostro VAM sits alongside the O2 VAM climbing bike for Israel-Premier Tech. Given that the Ostro can hit the UCI's 6.8 kg weight limit, it is the predominant bike of choice for the team.
Ostro VAM front end
The front end of the bike makes use of the UCI's relaxation on aero profiles with a deep head tube that also has a distinct hourglass profile to reduce frontal area as much as possible.
Ostro Vam front view
From the front view, the shape of the head tube is even more obvious, with it neatly transitioning to the fork crown.
Israel Premier Tech Black Inc. Cockpit
Black Inc. Is Factor's in-house component manufacturing division. It supplies the team with its integrated cockpit, bar tape and wheels. The bars that Williams' has gone for is the Integrated Aero Barstem. Also note the generous amount of tape for comfortable holding in the centre.
Factor Ostro VAM head tube
Williams doesn't run his stem completely slammed, instead, it is raised by around 15 mm above the headset top cap. Given that he is a climbing specialist, being in a position that better facilitates power delivery likely has a bigger gain than going for a full aero position.
FSA K-Force cranks
Although Israel-Premier Tech runs Shimano's Dura-Ace groupset, as a non-sponsored team they have decided to use FSA's K-Force cranks with a Power2Max Power Box spider-based power meter.
Chain catcher
Nestled in just behind the small chainring is a larger plastic 3D-printed chain catcher to prevent any untimely chain drops when shifting to the small ring.
T47 bottom bracket
The team is paying close attention to all the small details, with the T47 bottom bracket clearly labelled up as a Ceramicspeed unit. The vibrant blue anodising is nicely coordinated with the team's blue livery.
Cassette and drivetrain
The rear derailleur Di2 cable runs neatly from the exit port down to the derailleur, keeping it tucked out of the way. Williams has also opted for the 11-34 cassette ahead of the Tour Down Under.
Crank length 172.5mm
It is not all about short cranks it would seem. Williams (1.83 meters/6 feet tall) is sticking to 172.5 mm arms.
Black Inc. 48|58 wheelset
Continental provide the team with its rubber for 2025 with the GP5000 S TR (28 mm) the go-to choice. Williams has these tyres mounted to Black Inc's. 48|58 wheelset.
Front brake
The Ostro VAM sports asymmetric fork legs to allow for the brake caliper to mount in the correct position. The drive side fork leg is a standard straight profile all the way down, while the non-drive side leg tapers in towards the bottom.
Seat post and saddle
Wherever you look on the Ostro VAM you can't escapre the holographic Factor branding.
Saddle
Williams is using a Selle Italia SLR Boost Pro Team Kit Carbonio Superflow saddle. In a 130 mm width this saddle is the choice of many Selle Italia-supported riders.
Name sticker
No chance in forgetting who this bike belongs to with a perfectly placed name sticker at the top of the seat tube. And no Union Jack here; instead, note the Welsh flag with the red dragon on white and green.
Bottle cage
Sitting just above the dazzling Factor logo is Elite's Superleggero carbon bottle cage. The brand has released an even lighter cage called the T-Race, but as it only saves two grams over the Superleggero Williams is sticking with what he knows.
Ostro VAM chain stay
Sitting on the chainstay is Factor's slogan of 'Never. Status. Quo.'
Rear tyre clearance
At 183 cm (6'0'') Williams is riding a 54 cm frame, which is smaller than you might expect from someone of this height.
Front tyre clearance
The fork already has a protective sleeve over it ready to accept the race transponder.
Stevie Williams Factor Ostro Vam Specs
