Scope introduces more affordable R4.G gravel wheel
Scope has expanded its gravel wheel line with a new set of hoops aimed squarely at a more price-conscious audience. The R4.G follows much of the design language of the Artech 4.G, but is less than half the cost.
The new wheels feature the same rim profile as the Artech – with a 45 mm section and 38/28 mm external/internal width, but are molded without the Aeroscale textured surface. The tubeless straight side (hookless) rims are compatible with tires from 35-65 mm. The R-Series hubs are conventionally made rather than the 3D-printed versions on the Artech, but feature labyrinth seals and the same 36-tooth ratchet design. Sapim CX-Ray steel spokes replace the carbon versions on the Artech.
The final tally is a competitive 1,439 grams per pair (the Artech 4.Gs are 1,150 g by comparison) and a retail price of €1,698 or US$1,798. [Scope Cycling]
